1 - 17 of 17 Posts
I've got a question for anyone that uses the direct plug-in MP3 cord into their Scala Q2 headset. I was wondering what the charge-life of the headset is with the mp3 player playing the whole time. Or even with music being broadcast via BT. I'd hate to find out that I need to find a wall outlet every 2 hours or something.
Thanks,
Chris in Boston
I've got the Q2 and I don't see a place to plug in an mp3 player. Is there a model with and without that place to plug it in?
Are you sure that you have a Q2?
All Q2's have the port to connect a MP3 player the earlier Scala Rider and Scala Teamset models did not.
It's on the back side of the mic part that stays attached to the helmet. It ends up being just below the charging plug hole when everything is together.
Later,
Chris
In this situation that may not be quite correct K1W1 ;)
The Q2 I bought locally did not have the MP3 socket in it, I found this out after getting it home and unpacking it. So I took it back and they had to send away for a newer 'shelf stock' version. It is exactly the same box except it has a sticker on it on the right hand side, nothing else on the box recognises the fact it is MP3'd
I did not take a photo of the original box, but believe me, in the store when I returned it and had them side by side they are identical, except for that sticker.
fnord, if you just bought yours recently, you may have a case to return it and swap it out. When I bought mine, I specifically mentioned the fact I wanted it for MP3 capability and I had actually seen these in Coffs Harbour on a friends helmet, so I knew they were around.
Cheers
TS
Interesting every piece of information I have ever seen about the Q2 says they have the MP3.
I wonder who stuffed up.
The original Q2 did not have the MP3 plug. Watch for it if you're out to buy a set.
Cheers
Cheers
Good to know, at least I know I've got a fresh one! Does the "Q2" name mean it has two speakers? The last one I used was borrowed, and had only one speaker in the helmet. But that was a few years ago.
Thanks for all the info.
Chris in Boston
I've got two Team Rider sets (four helmets in all) that all have two speakers per set.
I think the Q2 just differentiates this from the earlier models (Team Rider and Rider) that used a different Bluetooth chipset
Bummer. I just got mine in December and it does not include the mp3 jack. I actually both 3 sets at the same time and when I pull out the little plug on the back of the mic part, there is no jack there to plug into.
I wonder if revzilla might swap it out with the newer one still? I'll see how it goes with them.
FYI jcmotors has the best price on Q2 $248 shipped...
got mine bout 4-6 weeks ago.
Neighbor bought one on my recommendation for same price.
Discussion Starter #13
Whoa. I just bought the Multiset so the wife could have one on her bike, and it was $278.89 including $4.99 shipping. Bought it from an amazon vendor. I shoulda checked there first.
Chris in Boston
RevZilla and Cardo Systems rock!
I just had to post my update. Matt from Revzilla contacted the manufacturer on my behalf and is going to send me the mp3 adapter at no charge. Talk about great customer service both from RevZilla and Cardo Systems.
I know I'm going back to http://www.revzilla.com/ the next time I need another accessory!
It will be interesting to see what arrives. The MP3 plyer is plugged directly into the main unit which is attached to the helmet, that is on the Q2 rider anyway. So, I cannot imagine what an 'adaptor' would be and how it would hook into the system.
So, please post a photo and an update when whatever arrives :)
Cheers
TS
1 - 17 of 17 Posts
