My 06 wee is suddenly burning gas at twice the normal rate, and there is black soot on the exit of the pipe. It still has power but feels like like it is running rough at crusing speeds, you dont notice it when in the hills and your rolling on and off the throttle a lot. any ideas?
Is your clock displayed? How long has it been since the air filter was replaced and the valve clearances checked?
running rich, and i'm not
clock works fine , i have not check either of the others, bike has 13000 miles. never off road.
It's close to the time the air filter and valves should be done anyway so that's a start. Having a clock means there is no fuel injection problem sensor problem bad enough to display a fault. Check that the brakes aren't dragging too.
