It takes about 2-5/8" of rise to clear the Scotts so most Rox risers won't work. No riser that replaces the upper bar clamp will work either. The Scotts mount has to replace the upper bar clamp.
I ordered a set of atv bars, but my cables wouldn't reach:headbang:
Any suggestions?
I got nuthin. The stock bars are perfect for me so I have not investigated any bar or riser options. I used to replace all my stock bars on touring bikes with Suzuki GT175 bars and the Strom bars feel similar.
There is a way. Contact Blair from SV Racing parts. This was/is exactly my dilemma, I need to use risers but also want the steering damper. This is probably the route I'll take once funds are available.
It presumably requires using the MV Risers from Germany....
But most likely cables/wiring will have to be extended.
