1 - 9 of 9 Posts
I know that a number of guys are using the Rox risers on their Stroms but is anyone using the anit-vibe type?
Standard:
Anti-vibe:
http://www.roxspeedfx.com/
M
Any issues with cable routing? I might look into a pair of these if its not too big a hassle.
Dunno, I'm looking for someone using them already. I'm thinking of them but want to know if they are worth the extra bucks. They shouldn't need new cables, they're a straight 2" and there are lots of guys (and gals) using the Genmar 1" up and 1-3/8" back risers with stock cables.
Are any of you getting a lot of vibration? None to speak of here...
I'm old, so more comfort is better. I am planning on getting risers so why not consider an anti-vibe riser while I'm at it? Just trying to find out if anyone has them and if they are worth the extra cost.
These look pretty interesting. I like the adjustability of moving the bars back and up. I might try the standard solids with 1-1/8" fat bars. 1-1/8" bars tend to flex and vibrate less.
Don't Work
I tried the Rox anti-vibe risers and they did not work. I was out to kill a little buzz but no cigar. I think these are more for 4 wheelers and do absorb big shocks. Besides, I do not think they will install without a second riser (they will not clear the triple clamp).
I have real short arms and had the Gen Mar up and back and the Rox anti-vibes together. Felt like ape hangars and handling was adversely affected. I do not believe this is your answer. Try good TB synch and gel grips. Maybe a 16 tooth front sprocket.
Just Bill
Gel Grips made a BIG difference in the comfort level on my DL1K
...I was out to kill a little buzz...
I usually try and nurse a little buzz...another beer, another shot... :D
Just Bill
Seriously, thanks for the info Bill. I have no real complaints about my Strom, I just thought it might improve on an already good thing. Done the TBS, a couple times, and changed out the grips. I'm looking to raise the bars and wondered if the anti-vibe was worth the extra $$.
1 - 9 of 9 Posts
