1 - 4 of 4 Posts
Diagnostic LED and brake light comes on and when CC power is turned on. Pull the brake lever and they go out. Other buttons will flash LED if brake is held, feel like I'm close, but brake relay wiring must be off just a bit.
There are so many diagrams out there, and some are wrong. I had printed a version of the 2nd one (without the 2nd relay) and soldered in a relay socket. I was pretty careful to write what went where, etc. and double checked, but it still was not working. I've cut out the socket and just have a relay with solder-less connectors (using a different diagram) and it's working now.
1 - 4 of 4 Posts
