1 - 20 of 20 Posts
When I picked up my Vee today my mechanic showed me the rear tire he had removed. There were two spots where my tire had been punctured & the ride on did exactly what it's supposed to do. It filled in those punctures & I didn't lose a bit of air pressure!
Well worth the $10 per tire in my opinion!
That's good info right there. I used Ride On in my last two Vees. The only flat I ever had, the Ride On failed. When I tried to plug the tire on the side of the road (mushroom plugs and gummies), I discovered the flat was caused by a one-inch gash. I couldn't stuff enough plugs in there to hold air. Not really a fair test for the Ride On. I think I'll give it another go.
I currently use Ride On and think it's been successful for me. I picked up a screw right in the middle of my rear tire and as the tires were practically new (and given the location of the plug), I decided I was going to continue to ride the tire. I normally have zero issues with plugs, but this time I had a very slight leak. I got tired to airing up every couple of weeks, so I decided to give Ride-On a try. I now find that even though I check pressure pretty regularly, I only need to add a bit of air every 3-4 months. I've never experienced tire pressure that was so stable.
Will Ride On protect me when I catch the next screw? I don't know, but I will say that I'm happy so far.
Is there any affect to the balance of the wheel using ride-on?
Seems like seriously good stuff. Wander if I will find it locally available...
Yes there is an effect on the tire balance...you can kiss the wheel weights goodbye as Ride On will continuously balance your tires!
What kind of mess is there to clean up during tire changes?
There is none. It isn't like Slime at all. Ride-On gels and skins over. It stays on the inside of the tire opposite the tread. It won't seal a puncture toward the side of a tire but a tire punctured far off center needs to be replaced anyhow.
Yup, that's how it looked to me. Nothing like slime at all.
thanks for the safety tip
Ride-On sounds like a big plus for rider safety, especially on freeways.
Discussion Starter #13
You're welcome. Whenever I buy a bike I get it to the shop as soon as I'm able to get this stuff put in.
I had a shaky front end on my Roadstar. Thought maybe it was bearings. It wasn't. Put in Ride On & that all went away. Plus, right after I put the car tire on the back of the Roadstar I got a nail in it. Pulled the nail out & it sealed right up. Never lost any pressure.
It won't do anything for sidewall punctures, but I think most of them occur in the middle of the tire typically anyway.
I originally put the ride-on in for vibration damping; it really works! I also feel I get longer life out of my tires, over 13K on the last rear. I did have a screw just outside the contact area of the ride-on which required a plug. Yes I plugged the rear tire with a mushroom type plug over 5 months ago with no issues. I also told the tire shop don't worry about balancing the tires as I was using Ride-on. :thumbup:
My only real complaint with Ride On is that the stuff is thick and it wasn't all that easy a transition from the bottle through the valve stem. Next time I'm going to let the bottles sit out in the sun for a couple of hours, or warm them in hot water before I begin.
Some are reporting good experiences using Ride On. I would conclude that using it would increase safety. Less chance of loosing control of your machine in traffic if a tire quickly goes flat. Who can argue with that? Also we should inspect tires occasionally for stuff.
Discussion Starter #19
Congratulations, that is certainly different from my experience: http://www.stromtrooper.com/general-v-strom-discussion/35027-ride-=-fail-story-flat-tire.html
I've switched to Ultraseal. No problems. A real mess when changing tires. Haven't decided to use it in the GS (TPM), but probably will at first tire change if I do it myself.
Of course, there is no substitute for a plug kit and air compressor.
That sucks. Glad you found something that works for you though.
So far Ride On has worked for me in 2 tires that I know of so I'm gonna stick with it until it fails me. I do carry a 12v compressor & plug kit now as well.
One concern with ride-on is the added half-pound of roda patting unstrung weight. Less unstrung weight and less rotating weight are always desirable.
Which is somewhat offset by the removal of wheel balancing weights - more so on knobbies, etc.
Still, you make a good point...
1 - 20 of 20 Posts
