1 - 9 of 9 Posts
So I was trying to move my windshield up from the lowest to the highest point on my 2015 VStrom 650 and I found out that if you're not careful, you can push the threads encased in rubber through the panel. Now I have one rubber thread somewhere behind the windshield (above the headlight) and I'm wondering what the easiest and/or best way is to access that area? (i.e. which panels to remove)
I'm relatively new at working on a VStrom, so I'm just looking for as much guidance as possible before I mess something else up haha
Thanks!
Yeah, I looked at the fairing and it looked like a hassle, especially considering I wasn't 100% where exactly the well nut fell. So yeah, bought new pack of 10-32 well nuts and installed the windshield. I was able to use the same screw.
I just adjusted my 2012 Adventure windscreen for the first time and lost one into the cowling. I got very lucky and was able to eventually shake it out (after some curse words and taking a break to shop for after-market screens). I removed the rest safely by running a length of electrical wire through the hole before removal. I then pushed them through the cowling and then pulled them off the wire.
For the life of me, I could not re-insert them from the front. The bulbous rubber middle would not push or twist through. So I used the wire again. I threaded the wire through the hole in the cowling, threaded the nut on the wire, tied a knot on the wire so the nut would not fall off, then pulled the wire and nut through the cowling (back to front). I used a small screw driver to gently pry the flat rubber grommet piece through the hole, then replaced the windshield.
The trick to inserting from the front is to thread the screw in a couple threads. Hold the rubber body while gently pushing the screw. This will stretch and thin the rubber body, allowing it to go in the hole.
In addition to above tip, one could also apply a soapy lube mix (diluted dish washing liquid) to the rubber.
The well nut requires a bit of friction to keep it from spinning when you insert the screw. I've never had to lube one. Just insert the screw a few turns and stretch the rubber a bit and it'll slip right in.
1 - 9 of 9 Posts
