1 - 12 of 12 Posts
Greetings gents!! This is my first post here.
I have a 2008 Vee and guess what>??? the rear shock is toasted. I ride two up most of the time on curvy bumpy roads here in Puerto Rico. I have searched for options and found the progressive 465 around what I am willing to spend on suspension upgrade. The shock could be sent to DMR or Sasquash for rebuilt, but I dont want to park the bike either....
I am 205 and the lady is 147... the spring rate is no bueno...
Any feedback from a progressive suspension user?
Thanks in advance
Can't speak to progressive.
Spring arte though should be 625/650 if you ride mostly solo, 675/700 if you ride two up a lot. Good luck
First number is front and then rear or is it the range? This would be the first time I seek changing a spring on a bike. Cars I've done bike no
no both numbers are rear . the first is a choice between 625/650 for riding solo and the other numbers if you ride with your wife a lot.
Those numbers are in pounds per inch (sorry for not specifying).
front forks should be either 0.95 or 1.0, this time measured in N/mm (don;lt ask my why most people switch between measurement systems between front and rear cause I don't know
I have the Progressive 465 w/RAP on the rear. Installed about 8 years ago and 52,000+ miles. I travel with side cases, top cases, a pillion bag, and tank bag which add 115 to 150 pounds plus my geared up weight of about 205 - 210 pounds. No problems or complaints and I have been real happy with its performance.
YMMV
281688
My 04 had a pretty tired shock at 50k miles or so. I picked up a used 465 w/RAP on this forum, reportedly with 10k miles. Major improvement. Full disclosure: I have mostly owned clapped out bikes with clapped out shocks, so the bar was low. But the bike is so much better now.
WIlbers has done well for me, mine is on it's second DL650, probably >200,000k's on it with two rebuilds. (I will point out that a shock rebuild is expensive, 20-50% of the cost of the shock) but it's performed extremely well and never let me down.
I know finding suspension rebuilders locally will be a problem and I'm not suggesting get a local to rebuild the existing shock but find out if there are any at all if they do exist and what shocks they like working/can get parts for with and choose from those.
I had Sasquatch rebuild mine. I was able to borrow a shock from a friend while mine was getting worked on.
So the bike wasn't out of service.
How can I find "Sasquash"? LOL but for real.
1 - 12 of 12 Posts
