1 - 3 of 3 Posts
Hi, new to forum---Need to replace damaged 2006 dl1000 gas tank--is the dl650 gas tank the same item or are they different? Thx
The both use the same fuel tank. However, there are two types. One vents through the cap and the other vents through a hose to a charcoal canister. It's best the get the same type or you have to play with it a bit. There is also the color match to consider.
1 - 3 of 3 Posts
