1 - 3 of 3 Posts
G
Does anyone know any 4-piston front brake calipers that will fit the 'Strom?
I'm going to be installing stainless steel lines, and I figured while I was doing the work, I might as well upgrade the calipers, too...if I could find something to fit on eBay.
So, what will fit? They're the same 2-piston calipers as the Bandit 600 and the Katanas, 55mm between bolt centers on the forks' brake mount tabs.
G
Discussion Starter #2
I'v sort of looked at the idea. You realy want to go 4 pots of a earlier GSXR ar Bandit 1200. Now I dont think any 4 pots will bolt up but just have a machinist make you addaptors, I'v done this quite a bit on some project bikes few years ago.
Vstrom sure can use a set of 4 pots thats for sure.
G
IMO the brakes are sufficient for the type of bike we ride and tires we use. HH or HH+ pads will allow you to stop with one finger as opposed to two with less applied pressure.
1 - 3 of 3 Posts
