1 - 3 of 3 Posts
I was late for an appointment and thought I'd zip over on my Frau's 2011 (the battery was dead on mine) as it was overdue for a run.
It was a little strange that I didn't have a neutral light ...but it started right up and ..well... I was running a bit late.
I had forgotten how nice the bike handled and was enjoying myself (it's running great) when I noticed that the fuel level wasn't reading ... nor was the temperature! I was confident I had lots of gas and made a note to check it out later.
I hit the expressway and after I passed the first few vehicles I checked my speed and my gauges (both speed and rpm) were at zero. Weird!
I made it to the appointment and the timing worked out well. when I came out I removed the seat to wiggle a few wires and look at fuses.
I found the dreaded mouse nest and after pulling out a small suitcase full of fluff I peered into the gloom under the top case and could see lots of copper gleaming. I drove directly home using hand signals.
Now that I've got that all apart and reinsulated I'm looking for a fuse (or link) but every fuse I look at seems to be fine.
I suspect something central as headlights and turn signals aren't working either.
Any suggestions on where to look?
Basically the bike runs great but I haven't got any electrics other than the horn.
Den
Discussion Starter #2
All the fuses including the 30 amp main seem fine. I am gbeginning to wonder if this is a different problem. Maybe the wiring harness ground on the 2011 is iffy?
1 - 3 of 3 Posts
