Ok. Am I the only one who finds the instructions in the manual about getting to the air cleaner frustratingly vague when it says “ Remove fuel line”. It looks like a clip that you just pinch the inside piece and it comes off, but no matter how much I squeeze the inside blue piece the fuel doesn’t get loose. Do I need some pliers to just pull harder or am I missing something
Depending on what connector you have …. If not this one, see the post below!
You need to pull the blue clip out sideways. It will come halfway out. That frees the hose. Make sure not to pull on the hose while pulling the clip out. Will make it harder to pull that clip out.
2018 update- I'm Back! This thread is being restored with the original photos, (some not so good - I know) They are now resident on this site in my Gallery Album. Enjoy, DSR650 How to lift the tank and open the airbox on the new VStrom 650. The model here is a 2012 DL650A-L2 ABS Adventure with...
Thanks guys. It’s a DL650 same one in my profile. Was able to figure it out after looking at post in the link. Pushing towards the fitting on the tank turned out be enough to relieve the tension. Kind of annoyed that thread didn’t show up in my searches originally wouldn’t of posted if I’d seen it.
All my Stroms have had green clips and at the top of the clip there is a slot just perfect for a small flat bladed screwdriver.
Push the fuel hose on just a little more to relieve the pressure, insert the screwdriver into the slot and twist, the clip should just pop up and the hose slip off.
Don't try to remove the clip completely at this stage, you can do it later if you wish but it is not necessary.
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
A forum community dedicated to all Suzuki Strom owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, purchasing, reviews, accessories, maintenance, and more!
