time to change my oem rear . i started to remove the nut when i loosen the nut maybe a 1/4 turn it feels like its getting tighter any suggetions 2014 wee 1st time for the tire to come off
Are you sure you're turning it the right way?... Keep turning it... and a tip... you have to use a wrench on the other side too... otherwise the axel may spin with the nut....
nut
i got it off with a breaker bar.i dont know if they ship these bikes with the tires on or if the dealer mounts them but that was waaay tight
Check that the threads are in good shape. Then use anti seize on them and torque to 58lb-ft like RCinNC's linked thread indicates.
