Check for "kinks" in the chain. If a link has lost it's internal lube, a kink will appear.
I spun it without the chain attached to the rear sprocket and there's no knock. With the chain on the sprocket and loose there's no knock. Only when I put tension on the chain the knock is there. I checked the front sprocket and it's still good. If it's the chain, there would have to be a bunch of links gone bad but all the rubber o-rings are still intack.If you remove the chain and spin the wheel, is the knock still there? (this would confirm bearings, brakes? or some sort of wheel-related knock).
otherwise -
Is the chain rubbing/knocking or getting caught up on a bad front sprocket?
Does the chain have a bad link in it?
Etc..
sounds like we have similar diagnosis procedures. LOLI spun it without the chain attached to the rear sprocket and there's no knock. With the chain on the sprocket and loose there's no knock. Only when I put tension on the chain the knock is there. I checked the front sprocket and it's still good. If it's the chain, there would have to be a bunch of links gone bad but all the rubber o-rings are still intack.
I have the tools to check the chain tension and alignment. I keep the chain between the recommended 20-30mm slackDoes the chain have sufficient slack??
Any chance the knock is from the chain interacting with the rear sprocket, not being 100% parallel?I spun it without the chain attached to the rear sprocket and there's no knock. With the chain on the sprocket and loose there's no knock. Only when I put tension on the chain the knock is there. I checked the front sprocket and it's still good. If it's the chain, there would have to be a bunch of links gone bad but all the rubber o-rings are still intack.
I replaced it also along with the wheel bearingsWhile you have the wheel off, check the carrier bearing as well. Mine knocked after it failed, and I could hear it even when turning the wheel slowly.
Run more slack and that should solve your problem.I have the tools to check the chain tension and alignment. I keep the chain between the recommended 20-30mm slack
Have you removed the sprocket and placed a straightedge across it to ensure it really is bent? The sideways force to have bent that in place would be quite massive.I pulled the wheel off the bike and put it all on the balancer.... I gave it a dozen spins and observed the sprocket (it's bent but I don't know how) and to see if the carrier is seated properly which is looks like it is. The brake rotor is also straight. I can't find any links in the chain that are bound up or loose.
