1 - 3 of 3 Posts
I'm not a heavy guy (bout 175lbs), but often travel with full 43L side bags and large top trunk, and sleeping bag/tent/air mattress strapped to the seat. I also like to have my suspension set pretty firm.
I just removed and modified the rear spring by placing a 3mm thick spacer between the spring and the spring preload adjuster. This gives me the approx equivalent of 3 lines of preload when now showing none.
I was able to use my automotive mcpherson strut spring compresser to remove the spring. I was also fortunate that the tiny allen screw wasnt seized (holds the spring preload adjuster in place).
I have Sonics in the front, so that is no problem and hopefully the rear will be satisfactory now as well.
Leaving for Nfld in just 4 more sleeps!
Cheers
How difficult was it to compress the spring and get the shock apart?
I have a Wilbers spring sitting in my garage waiting for me to be home long enough to install it.
With my spring compressor, it was very easy. Without it, forget it. This was also a good time to check the grease in all the caged needle bearings in the pivot points as well.
One of them was almost dry, but otherwise they were still greased. I did add some additional grease when re-assembling.
Cheers!
1 - 3 of 3 Posts
