Never does any harm, especially if You ride in wet weather a lot.
Pretty sure I'd be spending more time wrenching than riding here in Seattle if I followed that advice. 9 months of the year, every ride is a wet ride.I grease the parts that are highlighted in the owner's manual about once a quarter, though my dealership told me to do it after every wet ride.
Ok, maybe I'll get around to the pivot. Just ran out of give-a-sh*t today by the time I reassembled the cushion lever.When I have serviced the swingarm and the suspension links I saw a little amount of grease...
Correct. Grease the inner faces of the dog bones and outer faces of the bearing races.I'm almost done cleaning and re-greasing all the rear suspension bearings and linkages on my 2004 DL650, more or less as in the linked vstrom.info thread.
One thing from that thread that doesn't seem right: should you really grease the inner faces of the various nuts? Doesn't that mess with the torque values?
Agreed-both mine and my wife’s swingarm axle (2020 1050 XT ADV & XT) were almost completely dry.When I have serviced the swingarm and the suspension links I saw a little amount of grease...
Luiz Baum
Did you have to remove the shock when doing this?Agreed-both mine and my wife’s swingarm axle (2020 1050 XT ADV & XT) were almost completely dry.
The pain is the service manual specifies to remove the center stand and exhaust system for swingarm removal.
We were able to pivot (up and forward) the swingarm at enough of an angle to grease the right side bearings without removing. Left side was easy to get to if I recall.
You would certainly want to disconnect the lower shock mount and linkages in order to lube all those bearings as well while doing the swingarm bearings. They are all part of the system that makes the bike handle as designed and need to have sufficient grease.Did you have to remove the shock when doing this?
When I got into mine at 135k at the time I replaced the original shock, the needle bearings had completely disintegratedYou would certainly want to disconnect the lower shock mount and linkages in order to lube all those bearings as well while doing the swingarm bearings. They are all part of the system that makes the bike handle as designed and need to have sufficient grease.
Yep, there we go. It doesn't pay to not check and lube them early in their life. Also pays to not pressure wash them.When I got into mine at 135k at the time I replaced the original shock, the needle bearings had completely disintegrated
We did just to have better access to the front dogbone and swingarm bearings. As said above the bottom shock bolt definitely needs to come out and has bearings. Only one more bolt to get the shock out of the way completely.Did you have to remove the shock when doing this?
