1 - 9 of 9 Posts
New owner of used 09 here. PO took excellent care of bike, however two things about bike I want to change and hope someone here will know.
1- How do you properly re-install the rubber mat on the rear rack? I pulled the end off one of the "tits" after trying to shove them through the rack to no avail.
2-Does anyone know a source for the rubber sleeves that fit aroung the mirror stalks? Mine is missing the one around the upper RH swivel..
Thanks,
Tom Maxey
Roanoke, Va
Welcome!
Regarding installing the rubber mat, I have not done it myself, but I think it would help to lube the rubber 'tits' with some dish soap or something and push from the top side. I believe I used soapy water to remove my rubber mat that way.
Lubricating them and pulling them through with a circular motion is what has been suggested in other threads.
Personally, I plan to just cut them off and if/when I want the rubber mat back on I'll just use some rubber cement - pretty strong glue but not permanent.
Soap helps
I agree that soap helps, but I also used nail clippers to trim the rubber flanges of each tit just a bit. My pad is usually off, so I can bolt a box to the rack. Sometimes the box is quite large, but I can still see around it.
The boots around my mirrors were perhaps made of poor quality rubber, because they made my fingers dirty whenever I touched them. When one disintegrated, I brushed off the particles it left behind, and ripped off the other one, which partly crumbled in my hand. I left the stalks bare, but once in a while I think about painting them black ... just think about it and don't actually do it ... maybe some day. But then I couldn't ride the bike until the paint dried.
Keith
Thanks everyone.
I'll clip the tabs this weekend and put the mat back on.
The rubber around the mirrors is pretty chalky, and I noticed that as well. Anyone know of an inexpensive replacement mirror for the DL 650?
The rubber on my mirror stalks is also very dirty. I learned this the other day when I was handling the rubber to see how my mirror extenders were going to fit. Got to the office and found that I had left dark black smears all over my face from scratching an itch with my rubber-coated fingers. I looked like an american football player.
hi max
i just had the rubber pad off and on my rack the other night while mounting a shad trunk base.
to get the pad back on, i squirted i little bit of windex on the rubber nub, then pulled with a pliers, up and in a circular motion. after 6 or so motions, it popped through.
i ended up cutting off the back 2 nubs and using those 2 holes and drilling 2 other holes in the rack.
1 - 9 of 9 Posts
