I was putting on a new rear tire just before a planned ride and figured I'd check the bearings while I was at it. I have 43,000 mi. on my DL650. The wheel bearings felt OK, but the sprocket hub bearing was dry. I mean DRY. I could grasp the spacer between my fingers and spin it like a top for about 3 or 4 seconds. There was NO grease in it. There wasn't any noticeable play and it felt smooth and not notchy, so I figured I'd somehow try to re-grease it. The grease seal on the sprocket hub has been worn for quite some time and I should have replaced it long ago.
First, I tapped out the spacer from the inner race of the bearing. I got out my big bearing packer and was able to fit it to either side of the hub and put the grease gun to it. After scooping out a pound of extra grease from the bearing area and cleaning it all up with paper towels, I spun it and could feel plenty of resistance indicating that the grease had found it's way into the bearing. I took it for a 250 mi. ride with no issues and I'll run it until my new bearing set comes in. Maybe longer.
Wow that was pretty kool
And Knowing your penchant for DIY tutorials :fineprint: I'm sure your writing up the Whole step b step procedure with footnoted Photos:green_lol:
The wheel bearings felt OK....
Mine felt okay last week when I was changing the tire, but I didn't like the way they looked at all, so since I had a new set of bearings and seals on hand, I took a ride to Bettencourt's and Gary did the swap in about 20 minutes -- that beats the hell out of me attempting the job in the driveway without appropriate tools.
I also had a new sprocket carrier on hand since there was a stripped stud on the old one. (I'm down to my last one now...)
You know, I thought about going in the house and getting the camera, but I was running late to meet up for a lunch ride with a bunch of fellow ADV'ers. When I get my new bearings and have the carrier off, I'll put my bearing packer on there and do a little tutorial and photo shoot.
20 min. is quick for that job. Did you use OEM bearings? Did the carrier come with a bearing and seal in it?
When y'all are saying sprocket carrier bearing, are you talking about #14 on this diagram?
Yup, that's it and #15 is the seal that wears out very quickly and allows water to enter.
I replaced that brg with a sealed one.
Cheers
