I apologize if this has been discussed but a cursory search didn't bring up any related results.
I have installed the Ravetech skid plate on my 2014 dl1000 and I want to install the SW Motech center stand. Looking at the pictures on Revzilla of the center stand, it appears that it may mount in the same rear bolt holes that the skid plate is currently mounted in. Has anyone put these two together on their bike? Did it work? Did you have to modify anything? If they do not work together, is there another center stand that you would suggest that does work with the Ravetech? Thanks!!!
I've got both on my 2014 . They work fine together-no conflicts at all but I did have the center stand on first. I don't think that that will make any difference.
Excellent! Thanks for the info!
I have the ravetech with the OEM center stand and no problem... installed both myself.
Edit:. No problem with compatibility. However the Ravetech took finagling to get installed.
Sent from my Nexus 7 using Tapatalk
Nice, I have the SW centerstand and habe also been looking at the Ravetech plate. Good to know thanks!
