After laying my bike over about a year ago I am finally getting around to putting the 3/4" lowering links on the back and raising the forks 15mm (about .6 inches) in the front. That way I get lowering in the back and some lowering in the front.
I figured this post with pictures could help others and also confirm I am doing it correctly myself. I simply measured the distance it is protruding from the top. The left side is now approximately 15mm higher and the left side is flush. I loosened the three bolts and pulled down slightly on the crash bars and it moved higher until I got it where I wanted.
Can someone confirm this is what it should look like to actually accomplish the raising of the forks which lowers the front?
Thanks and hopefully this post with pics can clarify and help others.
David
David
