Is your bike too low, too high, or are you planning on carrying significant loads and need to raise the bike? If so, this may be your solution.
These links replace the stock linkage arms. The stock linkage arms measure 140 mm center to center. By increasing the length of the arm the back end and seat is lowered. By decreasing the length the back end and seat is raised.
We offer raising and lowering links in both 6061-T6 and 7075-T6 aluminum. Our 6061-T6 aluminum links are 3/8" thick and come with new 10 mm longer grade 8 bolts and washers. Our 7075-T6 and stainless steel links use the stock mounting hardware. Both are stronger than stock and come in a wide range of lengths to lower or raise you bike right where you want it.
They are equally strong and both stronger than the stock links. Some people just have preference so we offer both.
Raising Links
134 mm linkage set - raises rear of bike by 5/8 inches
133 mm linkage set - raises rear of bike by 3/4 inches
132 mm linkage set - raises rear of bike by 7/8 inches
131 mm linkage set - raises rear of bike by 1 inch
130 mm linkage set - raises rear of bike by 1 and 1/8 inch
Lowering Links
145 mm linkage set - lowers rear of bike by 1/2 inch
146 mm linkage set - lowers rear of bike by 5/8 inch
147 mm linkage set - lowers rear of bike by 3/4 inch
148 mm linkage set - lowers rear of bike by 7/8 inch
We will endeavor to keep most these in stock ready to go.
The links can be ordered on our webiste Raising and Lowering Links - AdventureTech, LLC.
Raising Links
Lowering Links
