1 - 9 of 9 Posts
I'm looking into buying & installing a radiator guard (more specifically the EG plate), but am a little concerned about blocking a good portion of the available area and creating a temp / heat issue.
Does anyone have any experience with this or other radiator guards and has anyone experienced any overheat issues after installing?
Not trolling, just genuinely curious. What are you worried about hitting it? The bottom of it is almost 2 feet off the ground.
No Clue, rode recently on a cool day and the fan was running at a red light. Not sure why. I also had it in the woods where it was hot, fan was on, it was fine. I also don't believe the thermostat gauge is accurate.
have a r&g radiator guard road in 90+ degrees and never went above 3 lines fan was working
Had bad experience once with a rock hitting and damaging my radiator (on another bike) - so ever since I've installed a radiator guard (cheap insurance)
I also had a bike where the guard reduced the amount of air flow enough so the fan was constantly on and the bike seem to be overheating - when it shouldn't have.
The EG guard that I am looking at - seems to be a little more air restrictive than some of the other ones - but also seems to be a little more "solid" than most.
Hence the dilemma.
I've had the Enduro Guardian version on for about a year with no apparent over heating. The guage only shows 3 bars max.
Screening.......
You might be surprised at how much air flow screening "can block". Look in McMaster-Carr at "Steel Wire Cloth". For example, a 3 x 3 mesh means 3 square openings "up" per inch and 3 square openings "across" per inch. Using a .120" wire diameter, gives you nearly 60% blockage of air flow....!!! The wire diameter greatly effects air blockage. Smaller diameter wire = less blockage, of course.
https://www.mcmaster.com/#standard-mesh-filters/=17dx90v
I would tend to believe the Rad Guards made from sheet aluminum with air slots (or holes), is blocking a good (bad??) amount of air flow.
I have guards on both my vstrom and CB500X........the X's guard is made by R&G Racing, don't remember who makes the one on the Wee.
1 - 9 of 9 Posts
