A while ago I ordered the Race Trac Gold Cartridge Emulators and Sonic Springs combination to fix the wallowing front end on my Wee. I contacted Rich Desmond at Sonic, and we decided that 0.9 rate springs were good for me. I have installed them (the installation was not that hard, except for drilling out the damper rod). But after installation, I now have too harsh a front end. So maybe someone can help me decide what I did wrong.
The install was:
2009 V-Strom DL650A
Race Tech Gold Emulators, yellow springs, stock settings (2 turns)
stock damper rods drilled out as per Race Tech instructions
0.90 Sonic Springs
12.5 wt oil (mixed 1:1 15 and 10 wts)
~450 ml oil level in each fork, measured space at 150 mm
stock spacer
I put it all together and the problem I have is that I have basically zero sag now. It is *very* stiff and this is with the pre-load adjuster all the way out. I actually measured sag using the "L1 - (L2+L3)/2" method and the calculation came out to 0.3 mm. That's not a misprint. Not 30 mm, 0.3 mm.
I am not sure how I ended up with essentially no sag, as I followed the recommendations from Race Trac and Sonic. I'm pretty sure I measured volumes and space correctly. So what do you suggest to adjust the suspension?
1. Go to lighter weight fork oil (7.5? 5?)
2. Cut down the spacer? How much? 30 mm plus preload?
3. Adjust the Race Trac emulator?
I think I am about to explore the dark arts of suspension tuning.
The install was:
2009 V-Strom DL650A
0.90 Sonic Springs
stock spacer
