1 - 2 of 2 Posts
Discussion Starter #1 (Edited by Moderator)
What air pressures do you recommend?
My bike has the Alpha Tecknik Lowering Link and I believe it has a somewhat shortened center stand. I can only get it up on the center stand after I put a 3/4 in piece of wood under the rear wheel. It is dang near impossible getting it down again!!! any suggestions?
Tire pressures vary by personal preference and tire type. Try pressures between those recommended on the bike's sticker or manual and the mark on the tire sidewall. Oil questions can only be addressed at http://www.stromtrooper.com/maintenance-how/30068-big-oil-thread-only-oil-thread.html
Stock links are 140mm between hole centers. Longer links lower the bike. You can go back to stock links if your legs are long enough.
1 - 2 of 2 Posts
