1 - 18 of 18 Posts
the horn came with an extension on the casting, and a bolt. I got the Walsh bracket yesterday.
Is this how it mounts? His directions only show it mounted.
TIA
I dont know, but if you can take some pics were you will install it and some write up.
Thanks Zygis
That's it. The U fits around the fairing frame member and the horn connection is how you show it. Keep the cylindrical part vertical.
Thanks. Are you Pat Walsh, or is the name a coincidence?
I am not Pat Walsh.
Frustration sets in. Hook up the bracket, Eastern Beaver harness, hit the button lights dim, but no horn!
And, I can't find my continuity tester to see if the relay is triiping and it's getting power. It was the last think I was going to do before I got it on the road. Grrrrrr.
You should hear the relay click. When I first tried mine, all I got was the relay click. I had no fuse in the fuse block. The lights should not dim. Try running a pair of wires directly from the horn to the battery for an instant to make sure the horn is working. Watch the polarity.
Doh!
Checked the leads to the relay with a multimeter - 12V. Checked voltage to horn: 0 V.
Then, a revelation: the horn will not work, no matter how many times you press the starter button!
How I got it into my head to push the starter button when there was a red switch with a horn on it, right in front of my face, but that's what I did! Time to start making AARP jokes......
The Eastern Beaver harness makes it pretty foolproof, but I proved a Greater Fool.
The first time I tried it, I did the same thing. The second time I tried, I just got a relay click. I hadn't put a fuse in. You're not alone.
Wow, I'm not the only genius on the board.
Doh!
That's a nice senior moment. Imagine how bystanders are going to feel when you try to start your bike and give them a big blast of STEBEL HORN!
I swear that sounds just like something I would do.
bogey78
The switches all change position depending on whether you're standing next to the bike or sitting on it. ;) My mind may forget but my thumbs know where the horn button is.
Discussion Starter #13 (Edited)
That's a nice senior moment. Imagine how bystanders are going to feel when you try to start your bike and give them a big blast of STEBEL HORN! //
Muscle memory - you usually walk up to the bike, switch the key on, then hit the starter. So I didn't think anything of it.
Great sound, though. Now my wife wants one for her minivan.
Discussion Starter #14
I finally got to use it today. This is a great safety addition!
It will fit up under the right side cowling so you don't have to look at it.
I put mine under the left side so that the horn was facing clear air.
Discussion Starter #17
Nowadays if I see someone glance in their rear view or side mirrors, I hit the button. This prevented two SUV's from joining me in my lane today. But it's Sunday, as my wife says, "It's their day."
I've had this setup (PW bracket & stebel horn) on my 02 V for about a year and while the bracket holds the horn snug it is very close to the left fork. It hasn't moved at all in a thousand miles or so though so I'm just keeping my eye on it for now.
I originally tried to mount it with hose clamps and I wasn't too happy with that as a permanent solution. The PW bracket is very robust.
1 - 18 of 18 Posts
