I picked up a rox riser off a fellow vstrom rider and I have a question about the install. When you attach the riser to the "stem" you can't really angle the riser to far front or back or you block the lower bolt holes. So you can take advantage of the rising part of the riser, but you can't really angle it towards or away from you because you block the hex heads that need to be tightened down. Am I doing something wrong or is this just the way it is designed?
