Any of you installed this with adhesive only? If so what did you use? Used google found lots of threads about fenda but nothing about this type of mounting. I would like to avoid the screws if possible.
TIA
TIA
ABS is Acrylonitrile Butadiene Styrene - basically rubber modified Styrene (for impact resistance). It is a very common engineering thermoplastic.I installed my fenda extenda 2 weeks ago. Be very careful with the cement. Make sure you use the ABS cement. It is a black color and is a little goopy in viscosity. I'm not sure what is in PVC cement but don't use anything with toluene as this will melt the extenda. The ABS is methyl ethyl keytone and that is what turns the extenda and the fender into one piece. //
