1 - 13 of 13 Posts
Ran them at 38/36 on the gravel and I found them amazingly sure footed. I was riding alot faster with them than the stockers. 40/38 on the blacktop. As others have noted, they are eager to lean into turns. I think the aggressive tread has more friction than the stockers and it slows the front wheel causing it to lay over. Pretty much used to it after a couple rides. Have yet to corner them hard but I did cruise up to about 105 indicated and the were smooth at speed. You can feel the blocks rumble a bit below 30 or so.
The blocks rumble and sing!
Talented tires, if you ask me.
I'm heading out West in a bit so I will see how I like them on road. Probably put 4,000 miles or so. If I didn't enjoy the scenery and solitude of the forest gravel roads I would have stuck with the Trail Wings.
Bikeless 4 now
Wait until you try the 805/804 combo. Same rubber compound with amazing blacktop performance, and way better off road. Plus they look great.
My 804 rubbed the fender on my Glee in dirt so now I have my TKC70 on. But the Shinko's are good tires for the money! Have fun and be safe!
Outbackwack
Your math is interesting. A bit off but interesting. I run 705's and find them quite adequate.
Oh, it's air pressure not road/dirt values. I just fall down so I don't worry about AP.:wink2:
Have about 2K miles on the 705's so far. No abnormal wear noted, just a hint of squaring off on the rear. They are much more compliant on bumps than the stockers. 40 psi rear and 38 front seems good for pavement and gravel.
I think my last three or four tire changes have been 705's. However, when this current one wears out, I may just try an 805 on the rear, and see how they ride.
Just put 705's on my DL650A and like the tread pattern for non-pavement and they seem to corner nicely and confidently. For the price, I am way happy!
Rmpl
UPDATE: After a few hundred miles on the Shinko 705 tires, front and rear, I ~~personally~~ do not like them. The front tire is very loud and the tires make the bike fall into curves almost too easy, as I find myself countersteering OUT of the curve to keep the bike on a nice line. It just wants to drop into a curve so easily. For the 5% dirt and rocky roads I ride, with 95% road use, the drawbacks to the 705's are not worth the decent off-road tread pattern they have.
Will sell them locally and have some Metzeler RoadTech 01's arriving this week and will ride these instead.
Rmpl
Shinko 705's and zero regrets 6k miles later. The front singing is now a whisper.
My checkbook likes them too.
Reactions: Cal
1 - 13 of 13 Posts
