On some bikes this is more pronounced when the motor is cold. Does your bike have the save drag with the motor hot as when it is cold? Does the bike shift fine? Is it 'clunky' when you put it into first?
A little drag is normal and I would expect the bike to be harder to push in gear with the clutch in than in neutral. 32,xxxx miles is not high mileage for a nicely treated clutch, but if the clutch has been misused (or just used hard) it could be getting worn.
