Good question. Not sure of the true fuction. The closest answer I have come across is as discussed in Protector in Master Cylinder
Yep I agree, if it's not installed when you bleed the brakes, and pump the brake lever, brake fluid will squirt out the top of the reservoir. Don't as me how I know this 😳 because I won't admit it.Diverter or baffle to keep the return fluid "muffled", I guess.
Same part(s) in the front brake and clutch master cylinder of my Goldwing.
So, it must cover up some kind of a through hole. I wonder if there is something about that little hole that is messed up on my master cylinder? All of a sudden I can't bleed the front brakes. Tried sucking with Mtyvac, pushing up with a syringe, nothing worked. I've got an OEM rebuild kit coming. Meanwhile I immersed the master cylinder in brake cleaning fluid hoping that would clean out anything that might be screwing things up.Yep I agree, if it's not installed when you bleed the brakes, and pump the brake lever, brake fluid will squirt out the top of the reservoir. Don't as me how I know this 😳 because I won't admit it.
