I have the ATV Highs and yes the id on the Pro tapers are smaller. My work around was to buy new bar ends from cycle gear and make my own compression lock to keep the bar ends in place. I did this by inserting a longer bolt through the bar end and using a 1 1/2" piece of rubber fuel line to compress in front of the nut. So as you tighten the bolt,the rubber fuel line is compressed to keep the bar end in place. You can even buy them color matching to your strom to add some bling.I don't know about you throttle lock issue. Good luck
