I want to replace my stock fork springs with "Progressive" progressive rate springs. The Progressive model number (for a DL 1000 K4) I’ve found in previous posts is : #11-1144.
None of the online sites I've shopped so far (Ron Ayers, Dennis Kirk etc.) list and Progressive models as compatible with V-Stroms. Yet, alot of people have them and speak highly of them.
Can someone clarify that the #11-1144s are indeed correct for the DL-1000 ?, and perhaps why no one lists them as compatible. Thanks.
TL - I don't know about Progressive brand, but Wilburs has progressive springs for the DL1000. I have them for my 650 and they made a huge improvement for me.
You may want to check into them if the Progressives don't pan out.
SpeedStar, What is the model number of your Wilbers ? Do you have specs on them (i.e. beginning and ending rates) ?
For reference I'm 6'5" 230lb. The spec on the 11-1144 springs is .710 - 1.16
TL - the Wilbers springs are .65 - .95 range for the 650. I don't know what the 1000 springs are.
I think the DL1000 part # is: 600-285-00 and they recommend 10wt oil with 150mm airspace.
Call Klaus at Wilbers USA. Let him know I told you about them.
ph# 732-786-9777
Hope this helps,
Devin
Update.
Thanks for all your replies. I went with the Progressive 11-1144 after confirmation these were the correct springs. A local dealer ordered them for me. $75.72 OTD. I haven't installed them yet.
I'm going to change out the fork oil as well.
I'm 6'5" 230lb. Any recommendations based on this particular spring and my weight ? Thanks again Strommers.
