Strom Trooper banner
1 - 1 of 1 Posts
You've probably seen the SpeedOut system on TV. It works! I rounded out a hex head on my 2014 650 tank. I can't be the only one to have rounded out a hex head due to its short depth. Don't do what I did and screw it back in hoping for the best. In short, I first used the regular screw extractor you can buy at any hardware store. I drilled out the head, and I tried two diameter extractors, but could not get a bite on the rounded head. I then realized the problem: the drill bits are cylindrical, and the extractors are cone shaped, so perhaps only 20% of the extractor was gripping, then slipping. I remembered the ad for SpeedOut, and found it at Lowe's for about $19. It worked the first time as the drill bit matched to the extractor head! Hint; drill in hard and fast, then flip the bit and extract slow! I used a 120v 3/8 drive as my rechargeable didn't have enough torque to extract a very stuck bolt.
See picture. BTW does anyone know where to get a replacement Suzuki hex bolt?
1 - 1 of 1 Posts
