1 - 4 of 4 Posts
I just picked up a 2017 DL650. The PO had Andreani cartridges installed. The springs are .88 on the compression side and .93 on the rebound side. The problem is I can only get 25mm of sag with the preload adjusters all the way out. He spec'd a rider weight of 200lbs which is the same as me. The carts came with the springs. The Racetech spring calculator specs .95 springs.
Any suggestions?
,90 is perfect for 180 pounds, might be a little light for 200. But if the adjuster doesn't allow the range, then perhaps you might check the spacer used with the andreani spring.
I agree with Motocanada. The spacer needs to be shortened. Try a 1/4" and see what happens.
1 - 4 of 4 Posts
