In the old format, we were able to sent private messages to another member, much like an intranet email system. What's the proper way to do that with the new format? The one method I thought would work seems to be more like leaving a message on a member's profile page that is open to everyone to view.
When you 'hover' your cursor over their avatar, a message option appears - see below. Go from there.
268488
Or you can click on your Avatar on the top bar next to the three dots, select Conversations in the drop down (you also see all your messages/PMs/Conversations), and then click on "Start conversation". You can enter a single member or multiple members to you PM, I mean Conversation.
Big Boy's is quicker though.
268494
How To Find Conversations (Private Messages)
From the navigation, near the upper right-hand corner, click on your avatar to open the drop-down menu and select “conversations”.
How To Delete A Conversation (Private Message)
There is no limit to the number of conversations. You can keep them indefinitely. If you choose to have one no longer display to you within your conversations, you can simply click near the upper right of the message to leave the conversation
Once you leave a conversation, it cannot be restored unless you are invited back to it.
For leaving conversations in bulk (full page) you can do the following.
That will open a drop menu near the bottom. Add a checkmark to "Select All".
Open your conversation box. Although you can add checkmarks next to each conversation, once you select any, a drop menu near the bottom will appear. If you want to leave conversation in bulk (such as a full page) Add a checkmark to "Select All".
Click the drop-down menu next to “Choose action” select “Leave conversations” . Click GO.
Jeff M
