I know, I should use direct power supply for my GPS, but I have a Walmart cigarette lighter in my tank bag that works like a dream. No disconnect whatsoever. I have the Dan Vesel dash and I thought it would be cool to install one in there along with the switch for my heated grips. The walmart lighter is not set up to be installed in a dash but screwed in on top and I want one that screws in like the marine sample below. The thing is that every other lighter I have used won't hold the charger cable in. They are too loose like the marine one and the charger will vibrate out or they are just crap like the Eklips setup that I had.
Anyone have a cig lighter setup that is as good as the walmart variety that will screw in the dash.
Walmart setup. Works like a charm but won't screw into dash.
Marine setup. Screws into dash and looks waterproof, but isn't tight enough.
BTW, I am thrilled that I own a low maintenance strom and can worry about simple things like this. :thumbup:
