Hey all,
Partly out of sheer boredom and cabin fever living in Michigan, I tore apart my '06 Wee with 10k miles, cleaned and adjusted everything, then put it back together. One of the things I did was a valve adjustment. 6 of the 8 were either out of spec or on the low (tight) end of the range. Also did a TBS (turned out not really necessary), chain adjustment, radiator flush, brake bleed, etc.
Now everything is back together and the bike is running great. BUT - the rear cylinder makes a pretty loud clicking noise which I assume is the cams banging up against the buckets. I only hear it when I'm idling or on the gas, and not when I close the throttle to slow down. This is definitely from the rear cylinder, where I changed the intake shims to go from a .102mm clearance to a .154mm clearance. I checked and double-checked the clearances before buttoning everything up. The rear exhaust valves were the only ones not adjusted.
To my mind, the noise is what a loose valve would sound like. But since the clearances are in spec, I know it's not loose. Has anyone experienced anything like this? I'm thinking I'll just leave well enough alone, since the valve clearances will eventually tighten up. But the clicking is pretty loud and annoying. There's no noticeable loss in power or fuel efficiency (though I haven't ridden through a whole tank yet so efficiency may be suffering a little). Any thoughts and ideas would be appreciated.
Cheers,
Brian
Cheers,
Brian
