1 - 3 of 3 Posts
If anyone who is at home can measure the diameter of the pin or button (whatever you call them) on the bottom of a Givi rack, I'd appreciate it. I am at work already and forgot it at home, but I want to make brackets to mount my new luggage. I will have to drill and cut a slot to slide over the two pins, just like Givi cases do. So I am looking for the diameter of the cylinder section of the pin, not the flared portion. Thanks if you are able to do that for me today.
John
I measured one of the "mushroom" posts that I have loose in the shop. It measures .39" or 9.8mm at the base of the mushroom.
Gary
1 - 3 of 3 Posts
