21 - 40 of 485 Posts
1
First of all, BIG THANKS to Criscokid for sharing the map I'm currently running on my 2005 DL 1000. It runs GREAT!!!!
One question though.
What "program" do I need to be able to download the .DJM files??
I can't seem to figure it out.
Any help would be appreciated.
Thanks.
Matt
Super Moderator
Thanks.
Matt
He knows how to do it now!!!!;)
Right I just down loaded CriscoSummer into my PC111 but upon re-reading MG's post realized that it was for a bike with aftermarket cans. I guess I should have downloaded one of Mighty Sheps or Cheffs and go from there. Bit of a hassle for me not having a laptop, I have to move her car out of the garage and put the bike in the back door so my 5m ext USB cable will reach. All the while enduring the over the glasses look with under the breath mumbling! LOL
Thanks heaps guys for all your input into this thread.:D
What brand of can did you put on your strom? All the after market cans I 've seen are straight through.
Discussion Starter #26
Unless you are running baffles, every aftermarket can is a "straight-thru" style pipe.
Try CriscoKid's map. His is tops for 04+ DLs.
Discussion Starter #30
I'd try the the BigB_V2 map I've posted earlier. Also try the Crisokid map. One or the other should work beautifully for ya!
Power Commander throttle position
So I'm trying these maps, thanks. Also when my bike is at idle the computer is telling my that I'm at 2% throttle. Is this normal? Does this mean my TPS may need adjustment?
This is the fuelmoto map for a k6 with Leo Vince pipes, stock air filter
So far, so good, average about 35mpg last tank with about 70 miles in town and 100 miles of freeway
Discussion Starter #33
I'd certainly check it. It takes all of about 5 minutes to jumper the connection and get a TPS reading.
anyone have one for aftermarket pipes (LEO SBK), and a home elevation of 7500 ft? does the fuel requirement change w/ the 2ndaries pulled?
scott
Oh My God!!!!!!!!!!!!!!!!!!!!
I got my DL1000 tuned today at a Dynojet facility. The gentleman asked me not to share his name if I was going to share the map for liability reasons so I will respect that. It cost me 200. And it is the best 200 I have spent on the DL. OH MY GOD AGAIN!!!!!!!!!! The bike is so smooth at all RPMs, it pulls hard with out the usual thumpin from below 2k rmp. I had trouble keeping my speed down because the engine is running so smooth. I have not scanned the sheet, but here are the numbers and the map. He said he was having trouble getting a full run because the TKC80 where to bouncy. He said that it prob would have gotten 90-92 with out knobbies.
Stock Dl1000 with K&N filter.
HP 88.08
Torque 61.80
That sounds pretty exciting Cheff. Do you think that map would work on a Canadian Model? Doesn't California bolt on more junk for emissions or are the North American models all the same? I have a K7 1000.
A guy on Advrider tried it with his '02 that he had for sale on their board. He said it helped so much he pulled the add. I would definitely give it a try, because I love the way the bikes runs with it.
Discussion Starter #38
Yeah, I ran it today. Phenomenal map, that guy knew what he was doing on a dyno.
I'm gonna have to richen up the 3700-4500 range b/c that's where my stock map is super-lean, and when I commute I spend a lot of time in 2nd and 3rd gear between 3500-4500 in the city. But overall, very impressive!! I love the low end and the upper part is smooth smooth smooth.
Glad you liked it MonkeyGrass, I am still in awe at how good my bike runs now. And I am upset I did not do it last year and 25k miles before!
Post the modified map here I would not mind trying it.
The gentleman also said that if I wanted better gas mileage I should use the buttons on the PCIII to lean it. This way I don't mess with the map, and I can do it on the road as needed. He said if I leaned it out all the way with the buttons I would go down maybe one jet size and I would not have to worry about hurting the bike.
I tried the latest map posted here today and it indeed runs smooth. I am going to richen it up some in the highway cruising RPM's. It just felt like the program was a little lean when rolling on to pass on the interstate. Otherwise a great map.
