1 - 1 of 1 Posts
Today I took the time to do the "under the fuel tank" maintenance. I replaced the spark plugs (E3) and air filter(K&N), removed the secondaries throttle valve and did the fast idle adjustment
I'm currently using the monkeygrass v2 map, I loaded it when I turned stock mufflers into glasspack, and the engine runs quite smoothly
Now, I just need to dial in the accel pump accordinglly to deal with the faster engine load change. Is there anyone that happen to find good settings?
1 - 1 of 1 Posts
