1 - 6 of 6 Posts
Part 1: I got a set of Pazzo's for my DL1K and the Wifey's Wee. Initally I didn't have a problem, but after 200 miles, the ball on the clutch lever on the 1K started to bump the handguard. Later it would actually interfere enough to hold the level in and I could let go and it would stick.
Easy to fix, I "Dremeled" out the plastic of the guard and problem was solved.
http://img201.imageshack.us/img201/8549/pazzoclutch0016zb4.jpg
Part 2: I got a set of handguards for the Wifeys Wee and the clutch lever adjustment lever would rub on the top of the guard. Out came the "Dremel" again. Problem solved.
Huh. No problems for me yet, but I'll keep an eye on it.
Pazzo vs Stock
As it turns out, the handguard at the end had started to come out from under the bar weight. Still, why the Pazzo hits it and the stock doesn't is a bit unnerving.
just get the short lever version no?
1 - 6 of 6 Posts
