Alright so during my crying above, bike cooled down while off. Now it's up to temp and no more drip. Crossing my fingers the universe heard my cries...
The new seal may have lapped itself in and you're good to go now.A few heat cycles, and it stopped leaking. Hope thats the end of it.
Yup, I've seen that before. Or perhaps there was a wee invisible speck of schmoo in there that worked itself out.The new seal may have lapped itself in and you're good to go now.
Wow, haven't been inside there yet. Sounds like a complicated mechanical nightmare, but Stromtroopers shall preservere!Yup, I've seen that before. Or perhaps there was a wee invisible speck of schmoo in there that worked itself out.
These mechanical seals are simply two very very flat and extremely hard discs of ceramic pushed together by a spring. Once in a while you get a bit of fluid before they get used to each other, or there's something microscopic in there.
It's also fairly easy to crack the ceramic during installation; most folks don't have a way to press them in, so you have to use a hammer... after this happened to me on my KLR, I always order two of the mechanical seals for water pump rebuilds because I really HATE having a bike sitting there open while waiting for parts. And yeah, I think combining the clutch cover and water pump like this is an extremely stupid design choice, but it is what it is, and it's pretty common unfortunately.
Good info. I always try to keep new seals clean, and if applicable lubed, but seeing as these type of seals are that sensitive it's entirely possible some dust or something found its way in there.A couple of things about mechanical seals…
Mechanical seals leak. They have to so that the faces are lubricated and don’t overheat from friction. They rely on a very thin film of liquid between the faces…appropriately 0.5 microns thick (20 millionth of an inch). A human hair is 10 microns thick. Because this liquid film is so thin, the “leakage” is so small that it’s undetectable and evaporates on the weep hole side without showing a drip. So, anything larger than 20 millionths of an inch that’s is on either face when assembling a seal will hold those faces farther apart and can cause leaking.
Sometimes it takes care of itself. The black rotating face on water pump seals are almost always carbon, and the white stationary face is ceramic (typically Aluminum oxide). Because the carbon face is softer, it can lap-in and conform to a bit of shwaz left there from the assembly process.
So that’s why I teach millwrights to never even touch the faces if possible. And if they did, give them a wipe with alcohol…but even then a lint free rag can be the source of contamination.
The ceramic / rubber seal at the impeller which interfaces with the mechanical seal on my DL 650 water pump just pushed in by finger pressure. The larger mechanical seal needed help from large socket to seat. Culprit for leak was failed KOYO rubber seal behind mechanical seal . Tapping razor blade around metal perimeter of mechanical seal gave room to pry it out with tiny flat blade screwdriver thus no need to pull bearings. No leaks but was careful installing that KOYO rubber seal with 15 mm socket as driver. Would have been nice if Suzuki spec'ed a double lip KOYO seal .Yup, I've seen that before. Or perhaps there was a wee invisible speck of schmoo in there that worked itself out.
