went for a little off road adventure today and took a light tumble. Wee is ok, but I bent the bar end pretty good. Since it was dangling there I decided just to unscrew it and get on with my day.
Got back to the garage, straightened everything out, went to go bolt everything back together and see that Suzuki uses an expansion nut which I lost on the way home :(
Anyways, I was wondering if anyone knew the suzuki part numbers for parts 7: EXPANDER,HANDLE & 8: NUT,HANDLE BALA below:
Thanks!
7 EXPANDER 56272-10G00
8 NUT 56273-10G10 (replaces 56273-10G00)
You just order those two parts. They total about $10. The entire assembly #2 is about $35. Do not use Loctite. There's no way to get at the #8 nut to hold it so the Loctite grip can be broken. The pressure exerted by the expander holds things in place nicely. Just loosen the screw no more than 1/2" and the entire assembly can be removed and replaced.
