After, ahem, modifying the bodywork Tuesday with a dog incident. I finally got up the nerve to bedliner the strom.
First things first, the damage. Not much at all.
Stickers are a PITA to get off, ever worse when they're rashed. A hair dryer on hot helps though.
Pull some more bits off it
Now we're naked
Rough them up with 220.
I used some adhesive and wax remover to clean them with.
I plan on doing away with the daylight invisible LED turn signals. Cagers can't see them. But the recess doesn't allow a flush mount.
Since it's not something you'll see I just drilled the area out. Hack yes, but this fairing has already had a big crack epoxied together. And there's a small chunk missing. So I don't mind.
After everything was sanded and prepped. I shot everything with two coats of adhesive promoter.
I began to shoot everything with my paint gun. Unfortunately, due to thickness, the liner clogs it easily. So I rolled three coats on with a roller.
No ADV bike modification could be complete with some sort of new farkle. I hate the stock horns bikes come with. Hopefully the cagers will notice these.
However, after putting the bike together more. I found out that the fan would hit one of the horns. So I relocated it.
Why they put these horns on bikes, I do not know.
Lord Vader, your motorcycle is ready...
Me likey.
Looks good - I like the bed-liner look the more I see it. So did you start out with a red bike, then add blue plastics?
The salvage title said blue...
The bodywork came from ebay. Honestly the tail was the only parts that actually matched.
Can you say Road Warrior. Where's Mel?
