I would check to make sure the ABS works on both the front and rear. I have two stickers on my bike and I have ABS on the front and the rear. You may just have it in the front or just on the rear because of the one sticker.Thanks for the replies.
It will be interesting to see if more bikes start showing up with just one sticker.
Jon...
....or maybe it only works while making right or left turns, depending on which side the sticker is on.I would check to make sure the ABS works on both the front and rear. I have two stickers on my bike and I have ABS on the front and the rear. You may just have it in the front or just on the rear because of the one sticker.
Welcome back to the Stromberhood.
I think he said it's on the top of the fender.....or maybe it only works while making right or left turns, depending on which side the sticker is on.
Well if the sticker is on the TOP of the fender, that's different and I'm sure that he can assume his ABS will work while making both left and right turns, and I'll even venture to say that it'll work on both wheels too!I think he said it's on the top of the fender.
Let me check:
"and some only had one on the top center of the fender"
Yup, top of the fender. My guess (and it's only a guess folks) is that since ABS is now standard on the DL-650, Suzuki doesn't feel the need to market it as agressively by festooning the bike with so many stickers.
I'm curious that you noticed a difference in fit and finish between the single-stickered and double-stickered bikes. I'd be intereded in your elaboration.I was more curious than anything else and figured someone else may wonder about it so decided to post the question.
Jon...
It was more of an overall feeling than anything else.I'm curious that you noticed a difference in fit and finish between the single-stickered and double-stickered bikes. I'd be interested in your elaboration.
Not in my case since it appears it was supposed to be that way.Would a missing sticker be covered under warranty?
I'm just sayin…
-Kevin
The extra weight evens the performance figures though.:green_lol:Got a White 2011 mfg date 12/2010 with 2 ABS Stickers. I hear the bikes with 2 stickers go faster than those with just one. The 2nd sticker is worth about 10hp![]()
