I'm sure these questions have been asked many times before but I'm new here so here goes. First, Is the maintenance on a wee within the reach of an average garage mechanic? I've been riding a KLR for 6 years now and have learned to enjoy the valve adjusting and doohickey replacement and all the rest. Any special tools or skills needed? Second, I feel silly for asking this but some stroms have silver wheels, most seem to have black ones. Is this year/model specific or is it a owner/custom thing? (BTW which color is faster?) Thanks
...First, Is the maintenance on a wee within the reach of an average garage mechanic? I've been riding a KLR for 6 years now and have learned to enjoy the valve adjusting and doohickey replacement and all the rest. Any special tools or skills needed?...
I am often surprised at how few tools are actually required - I am seldom required to go beyond basic a Craftsman socket set, hex sockets, and combo wrenches, plus some larger sizes for axle removal. Getting into steering head and frame work will require a few more specialty bits. Oh, and fork damping rod removal requires a special tool, or simple workaround. Oh, oh, one of the cover bolts to access the front sprocket is deep with limited clearance. You should be fine.
Is the V-Strom maintenance intensive?
...Second, I feel silly for asking this but some stroms have silver wheels, most seem to have black ones. Is this year/model specific or is it a owner/custom thing?...
Both. Some early owners stripped and polished their rims. Some recent models (maybe some older ones, too, I don't recall) are silver from the factory. Early models had silver frames/swingarms, too.
DL650 Through the Years!
...(BTW which color is faster?) Thanks
'06 Euclase silver metallic - it can take Ducs in the twisties, 'Busas on the straights, and holds almost every speed and endurance record in motorcycling, though the owners are all to modest, self-confident, and good looking to deign to officially register such banalities.
Former 2x DL650 owner; moved onto Super Tenere ES
Not sure if you purchased yet or not ... but these are very easy bikes to work on. The battery/starter/lack of choke makes starting very reliable even if it has sat awhile. Nothing like fuel injection. With such good fueling spark plugs also seem to last a long time. As said before, very few special tools aside from very large hex/allen key for fork damper rod and special tool if you ever wish to replace steering stem bearing (usually good for 25,000-30,000 miles or more if 100% road use). Valve adjustments are infrequent (rarely out of spec before 20K, sometimes double that) but do require inexpensive shims rather than a simple screw to be tightened. But checking the valves is essentially the same as your KLR.
Pretty easy to work on but what they are neglecting to tell you...and which pisses me off on a "sort of dirt bike" is the tank must be removed to R&R the air filter.
Now at home this is a 1 to 2 hour hassle with little bits and pieces to keep track of. In the woods...I would not think of even trying to look at filter unless the beast sucks up a slug of water or such. On my XR, two quick clips and your in filter land.
Yes, I know its a V twin with a perimeter frame.
Other than that little detail...its just another motorcycle.
