1 - 2 of 2 Posts
Hi, my Suzuki boulevard vl800 2012 have a problem on level gauge, I put the switch on, and mark fine, but after I release the stand after 30 seconds approx, the lights bars go to one bar and flashing,I change the cluster and the sender unit, i make jumper on plug of the stand and do the same thing, the stand switch is fine, I make test to the plug on sender unit under the tank and look good. Somebody have any idea how can I fixed. Thank.
It MAY be different, but I have the '07 VZ800 Suzuki Service manual. It shows resistance settings at each lever sensor height position, and resistors to be used on the sending unit to get the different gauge readings. Have you checked continuity between the cluster and the sending unit?
1 - 2 of 2 Posts
