1 - 15 of 15 Posts
Can someone, PLEASE, snap a picture of the owners manual on the pages to set the freaking clock.... It's about 3 hours fast... or 9 hours behind.... cant figure that out.....
Its pretty easy once you know how.
Push the Sel and ADJ buttons at the same time, hold for 3 or 5 seconds or something, you will see the clock start to flash. Change the hours with up/down on mode button, then hit ADJ to move to minutes and repeat, when done you hit Sel and Adj together again.
I think that is all you need to do, let me know you get stuck and I will go have a look.
A simultaneous button push is not so easy. Push the right button a little early and it won't work. Push the left button a little early and it works fine.
Hmmm... at that managed to do was reset the trip meter
position of the key matter??
650 different from the 1000???
It sounds like you weren't holding down the select button or didn't press it first before you pushed the adjust button.
tried it 20 times 5 different ways..l am stupider than a clock...
Reactions: IDRIDR
Well that worked.... I am now time compliant. Thanks all...
Wait a minute..... do you all play this trick on all the new folks??????
Reactions: IDRIDR and Bugzy
Lots of people only look at the most recent posts and don't look at the forum they are under, so it can get a little confusing sometimes, but we all mean well. :)
Speak for yourself. I don't mean well!
:wink2:
1 - 15 of 15 Posts
