There's no real mystery here, the engine was low on oil and the topmost parts were the first to go. Post mortem shows that the rear cylinder intake camshaft journal seized up. The bearing surface of the aluminum head is galled and unusable, so I am shopping for a used cylinder head.
But I would like to understand better why my valve timing is so far off. The '04 Vee has a chain driven idler gear that drives the 2 camshafts. I can rotate the crankshaft until the gear timing marks align with the top edge of the cylinder head exactly as described in the Haynes manual. But when I do that I see 2 things:
1) looking through the inspection port to the surface of the rotor I am nowhere remotely close to the F|T mark (or the R|T mark for that matter.) I am about 1-1/3 crankshaft turns away from the mark. So I am pretty sure the chain slipped on its sprockets. Maybe that is normal for a seized camshaft.
2) the lobes of the intake camshaft are nowhere near the position described in the manual (p. 2.22) The exhaust lobes are right where they should be, "nine o'clock," but my intake lobes are not at "11:30" as show in the diagram but rather at "6:30" actuating the valves. So I have to conclude that the camshaft has spun relative to the gear. Again maybe this is normal behavior and part of the Suzuki engineering to prevent worse damage.
So I know I need a head with valves and camshaft because the bearing in the head is shot and at least my intake camshaft has rotated relative to it gear. Question is will I want to replace cam chain, guides, tensioner and lower sprocket? I ordered the 20mm bolt to take the rotor off this weekend and complete the inspection.
Funny that the one camshaft to get out of alignment happens to be the one that actuates the position sensor. Since the bike un-seized immediately and turns over effortlessly I was wondering why the bike wouldn't start on one cylinder. Now I know.
Thanks in advance for any insights and yes I will be better at checking my oil level from now on!
