Good day all, I have been using this forum alot repairing my 2005 dl1000 that i bought as a "running but needs tlc" bike. A few months back i fixed all the problems that I could find but recently my cam position sensor on the rear cylinder died. I bought a new sensor but upon installing it i noticed there is no oil on the cams of the rear cylinder. When I turn over the engine with the cover removed there is also no oil flowing to the cams. During my problem solving process I found that there is oil flowing to the front cylinder cams so I am assuming the oil pump does work. I cannot find were the oil ports/ jets is located for the rear cylinder to check for blocked passages and ports. ANY advice would be aprreciated.
